주요 콘텐츠로 건너뛰기
Tent Pole Shock Cord Replacement
필요한 것
  1. Tent Pole Shock Cord Replacement, Tent Pole Shock Cord: 1 단계, 이미지 1/1
    • Remove the old shock cord from the tent poles.
  2. Tent Pole Shock Cord Replacement: 2 단계, 이미지 1/1
    • Measure and cut the string to the length of one tent pole piece.
    • Be sure to leave enough room on each end for knots.
  3. Tent Pole Shock Cord Replacement: 3 단계, 이미지 1/1
    • Tie the string to the end of the shock cord.
  4. Tent Pole Shock Cord Replacement: 4 단계, 이미지 1/2 Tent Pole Shock Cord Replacement: 4 단계, 이미지 2/2
    • Use your hands or pliers to flatten out a bobby pin.
    • Any long, thin, metal object will work to help feed the string and cord through the poles.
  5. Tent Pole Shock Cord Replacement: 5 단계, 이미지 1/1
    • Tie the string around the end of the bobby pin.
    • The string and bobby pin will be used to feed the shock cord through the pole.
  6. Tent Pole Shock Cord Replacement: 6 단계, 이미지 1/3 Tent Pole Shock Cord Replacement: 6 단계, 이미지 2/3 Tent Pole Shock Cord Replacement: 6 단계, 이미지 3/3
    • Drop the bobby pin and string through the tent pole pieces one by one.
    • Once the bobby pin reaches the opposite end of each pole, slowly pull the string to feed the shock cord through.
  7. Tent Pole Shock Cord Replacement: 7 단계, 이미지 1/2 Tent Pole Shock Cord Replacement: 7 단계, 이미지 2/2
    • Once the last piece has been threaded, untie or cut the string from the shock cord.
    • Tie a large knot against the right end of the last piece.
    • The knot must be large enough to prevent the shock cord from slipping through the pole.
  8. Tent Pole Shock Cord Replacement: 8 단계, 이미지 1/2 Tent Pole Shock Cord Replacement: 8 단계, 이미지 2/2
    • Connect the tent poles.
  9. Tent Pole Shock Cord Replacement: 9 단계, 이미지 1/1
    • Cut the shock cord from the left end of the first pole piece leaving room on the end for knots.
    • Leaving extra shock cord on the end will also allow you to adjust the tension in the shock cord later on.
  10. Tent Pole Shock Cord Replacement: 10 단계, 이미지 1/2 Tent Pole Shock Cord Replacement: 10 단계, 이미지 2/2
    • Tie a large knot around the tent pole end piece.
    • Fit the end piece into the left end of the first pole.
    • If your poles do not come with an end piece, simply tie a large knot in the shock cord. The knot must be large enough to prevent the shock cord from pulling through.
  11. Tent Pole Shock Cord Replacement: 11 단계, 이미지 1/1
    • Disconnect the pole pieces.
    • Fold the pieces to test the shock cord tension.
    • If the shock cord is too tight, reconnect the poles and adjust the shock cord length between the left end of the first pole and the end piece.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kelsea Weber
회원 가입일: 11/12/15
19,857 평판
안내서 32개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,718개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 27
전체 시간: 20,360
