주요 콘텐츠로 건너뛰기
Testing Power Cord Continuity
필요한 것
  1. Testing Power Cord Continuity, Set the multimeter to continuity test mode: 1 단계, 이미지 1/2 Testing Power Cord Continuity, Set the multimeter to continuity test mode: 1 단계, 이미지 2/2
    • Unplug the power cord from the device and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a diode or sound wave symbol as seen in the pictures. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
  2. Testing Power Cord Continuity, Test for a break in the cable: 2 단계, 이미지 1/1
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will continuously beep. A short beep does not mean that there is continuity. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
    Est-il possible de brancher sur une autre prise alimentée pour savoir si cordon et appareil sont non défectueux ??? Sans danger; faire sauter fusibles etc. Merci.
    maddy lode - 답글
    Could that be the problem why I am not getting but just a tad of electricity to my outlets I'm not getting enough power to run anything?
    mellichampc - 답글
  3. Testing Power Cord Continuity, Test for a short: 3 단계, 이미지 1/1
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
    is there a guide like this very useful one but to test the surface power cords ?
    david burchall - 답글
결승점
다른 146명이 해당 안내서를 완성하였습니다.
Darren Chan
회원 가입일: 10/28/09
5,321 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 21개 작성하였습니다
댓글 13개
Thank you very much.
Kaky Jerry - 답글
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Muhammad Imran - 답글
Brilliant love it
Liam Breen - 답글
Worked like a charm I feelik an electrician
hadpaulkh - 답글
I found this really wonderful and useful with details explained very well. I was always wondering what the electricians do with a multimeter. Now iI would buy one multimeter and do this on my own. Great and cool guide. Write more guides for other tests and verification.
Avinash S - 답글
great job i love
fcradiony - 답글
Superb...thanks a lot!!
chella narayanan - 답글
Thank you….. very useful
raj.bm13 - 답글
Great guide very helpfull.
Anthony - 답글
Now I know how to test a power cord.
How do I test a switch?
Frank Lawrence - 답글
Can you do a continuity test on the Xbox One Original CONSOLE ?
Anas Faisal - 답글
if one side of an extension lead is permently connected to electricity and it's unreachable, is it ok to test it from one side only?
reoc z - 답글
can i check an extension cord from one side?
does it should the electricity switched off, even if i’m using a proper testing machine?
reoc z - 답글
댓글 쓰기
조회 통계:
24 시간 전: 98
7일 전: 552
30일 전: 2,615
전체 시간: 228,938
