주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Testing Power Cord Continuity
필요한 것
  1. Testing Power Cord Continuity, Testing Power Cord Continuity: 1 단계, 이미지 1/1
    • Unplug the power cord from the game console and from the AC outlet. Failure to do so can result in electrical shock or death.
    • Set the multimeter to continuity test mode.
    • The setting is symbolized by a "volume indicator" as seen in the picture. If the meter is set to the correct mode, you should hear the meter beep when the leads are touched together.
    • Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
  2. Testing Power Cord Continuity: 2 단계, 이미지 1/1
    • Test for a potential open circuit by using one multimeter lead to touch one of the prongs on the AC side of power cord. Use the other lead to touch one end of the console side of the power cord.
    • If there is an adequate electrical connection, the multimeter will beep. If it does not beep the first time, try using the lead to touch the other prong.
    • Repeat the above directions in step 2 for the other outlet and prong of the power cord.
    • If the multimeter fails to beep on any of the occasions outlined above, your power cord is open. In other words, you will need to replace the power cable.
  3. Testing Power Cord Continuity: 3 단계, 이미지 1/1
    • Once you have verified that the power cord provides an adequate electrical connection, you will have to test that the cable is not shorted.
    • Test for a potential short circuit by touching each prong on the AC side of the power cord.
    • If the multimeter beeps, your power cord is bad and must be replaced immediately.
    • If your power cord is shorted, do not attempt to replug the cord into the AC outlet.
    • If your power cord has passed all of the steps above, then you have successfully tested that your power cord is in working order.
결승점
다른 146명이 해당 안내서를 완성하였습니다.
Darren Chan
회원 가입일: 10/28/09
5,321 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-1, Regan Fall 2009 Cal Poly, Team 5-1, Regan Fall 2009 회원
CPSU-REGAN-F09S5G1
5 회원들
안내서 21개 작성하였습니다
댓글 13개
Thank you very much.
Kaky Jerry - 답글
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Muhammad Imran - 답글
Brilliant love it
Liam Breen - 답글
Worked like a charm I feelik an electrician
hadpaulkh - 답글
I found this really wonderful and useful with details explained very well. I was always wondering what the electricians do with a multimeter. Now iI would buy one multimeter and do this on my own. Great and cool guide. Write more guides for other tests and verification.
Avinash S - 답글
댓글 쓰기
조회 통계:
24 시간 전: 86
7일 전: 618
30일 전: 2,647
전체 시간: 228,364
