주요 콘텐츠로 건너뛰기
Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement
필요한 것
  1. Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: 1 단계, 이미지 1/3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: 1 단계, 이미지 2/3 Teufel Airy Headphone Battery/NFC Antenna/Left Speaker Replacement, Open casing: 1 단계, 이미지 3/3
    • Unlatch hooks all around the left casing (three on each side)
    • Carefully lift cover, fold it over and tape it to the head piece to get it out of the way. The NFC antenna is glued to the cover. Two wires connect it to the bundle.
    • Pry battery out w/ a spatula. You'll gain access to the speaker cables and can unsolder and replace the battery, if needed.
    • In case you need to get to the speaker, see https://de.ifixit.com/Anleitung/Teufel+A... for details.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
andre
회원 가입일: 03/12/12
1,701 평판
안내서 4개 작성하였습니다
댓글 한 개
Thank you very much for this guide!
Patch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 410
