메인 콘텐츠로 스킵하기
소개
When your calculator's display turns on and right back off, it is time for a new battery. Replacing the battery for the TI-15 will take approximately less than 10 minutes to get you back in business. This guide will show you step-by-step the replacement for a TI-15 battery.
부품
지정된 부품이 없습니다.
  1. With a Y000 screwdriver, loosen the four 1mm Phillips head screws and set them aside. With a Y000 screwdriver, loosen the four 1mm Phillips head screws and set them aside. With a Y000 screwdriver, loosen the four 1mm Phillips head screws and set them aside.
    • With a Y000 screwdriver, loosen the four 1mm Phillips head screws and set them aside.
  2. With an iFixit opening tool, pry apart a total of 3 notches on the top and bottom of the calculator. With an iFixit opening tool, pry apart a total of 3 notches on the top and bottom of the calculator. With an iFixit opening tool, pry apart a total of 3 notches on the top and bottom of the calculator.
    • With an iFixit opening tool, pry apart a total of 3 notches on the top and bottom of the calculator.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Separate the two panels to reveal the calculator's green circuit board. Separate the two panels to reveal the calculator's green circuit board. Separate the two panels to reveal the calculator's green circuit board.
    • Separate the two panels to reveal the calculator's green circuit board.
  5. Using the iFixit opening tool , slide underneath the battery cover until the battery comes out. Using the iFixit opening tool , slide underneath the battery cover until the battery comes out.
    • Using the iFixit opening tool , slide underneath the battery cover until the battery comes out.
  6. Remove the old battery and insert the new battery. Properly dispose or recycle the old battery. Properly dispose or recycle the old battery.
    • Remove the old battery and insert the new battery.
    • Properly dispose or recycle the old battery.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
kayla neal
회원 가입일: 2016년 10월 06일
125 평판
안내서 1개 작성함
University of Memphis, Team 4-1, Baddour Fall 2016 University of Memphis, Team 4-1, Baddour Fall 2016 회원
UM-BADDOUR-F16S4G1
2 회원들
안내서 1개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 1,171
