주요 콘텐츠로 건너뛰기
Texas Instruments TI-30Xa Battery Replacement
필요한 것
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: 1 단계, 이미지 1/1
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: 2 단계, 이미지 1/2 Texas Instruments TI-30Xa Battery Replacement: 2 단계, 이미지 2/2
    • Locate the six screws on the back of the calculator.
    • With a Phillips #0 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: 3 단계, 이미지 1/3 Texas Instruments TI-30Xa Battery Replacement: 3 단계, 이미지 2/3 Texas Instruments TI-30Xa Battery Replacement: 3 단계, 이미지 3/3
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: 4 단계, 이미지 1/1
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: 5 단계, 이미지 1/2 Texas Instruments TI-30Xa Battery Replacement: 5 단계, 이미지 2/2
    • The two LR44 batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
결론
다른 55명이 해당 안내서를 완성하였습니다.
Chris L
회원 가입일: 12/17/14
1,522 평판
안내서 3개 작성하였습니다
댓글 30개
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
Scott Julien - 답글
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Dewellah - 답글
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
lasharlavenue - 답글
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
Esther Reese - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 69
30일 전: 275
전체 시간: 114,812
