주요 콘텐츠로 건너뛰기
Texas Instruments TI-83 Plus Backup Battery Replacement
필요한 것
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: 1 단계, 이미지 1/2 Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: 1 단계, 이미지 2/2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: 2 단계, 이미지 1/1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
결론
Clay
회원 가입일: 10/01/12
38 평판
안내서 1개 작성함
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 회원
CPSU-REGAN-F12S18G37
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Will this wipe the memory?
John Osborne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 19
30일 전: 111
전체 시간: 21,373
