주요 콘텐츠로 건너뛰기
Texas Instruments TI-83 Plus Individual Keys Replacement
필요한 것
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 1 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: 1 단계, 이미지 2/2
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: 2 단계, 이미지 1/1
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: 3 단계, 이미지 1/1
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: 4 단계, 이미지 1/1
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: 5 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement: 5 단계, 이미지 2/2
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 6 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: 6 단계, 이미지 2/2
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: 7 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement: 7 단계, 이미지 2/2
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 8 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: 8 단계, 이미지 2/2
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: 9 단계, 이미지 1/1
    • Clean the contacts on the keyboard with a soft cloth.
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 10 단계, 이미지 1/2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jared
회원 가입일: 10/02/12
151 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 회원
CPSU-REGAN-F12S18G37
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 20
전체 시간: 4,713
