소개
If your screen Or motherboard is broken this guide is for you. The screen is tethered to the motherboard, so both items must be replaced at the same time.
  1. Remove the battery cover. Remove the AAA batteries from the calculator.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Use plastic opening tool to remove the backup battery.  Place the tool in the small cut-out next to the battery and pry the battery out.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  6. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart. Pry back case off.  Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  7. Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out. Remove the eight (8) 5mm Philips #00  screws on the motherboard.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  8. Carefully remove the motherboard and screen.  Grab the board by its side with one hand and the screen with the other.  Carefully lift the two parts up. Keep the face-plate face-down to prevent the keys from falling out.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Kevin
회원 가입일: 2012년 10월 02일
374 평판
안내서 1개 작성함
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 회원
CPSU-REGAN-F12S18G37
5 회원들
안내서 5개 작성하였습니다
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - 답글
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - 답글
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
조회 통계:
지난 24시간: 7
지난 7일: 71
지난 30일: 304
전체 시간: 39,740
