주요 콘텐츠로 건너뛰기
Texas Instruments TI-92 Batteries Replacement
필요한 것
  1. Texas Instruments TI-92 Batteries Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Texas Instruments TI-92 Batteries Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Texas Instruments TI-92 Batteries Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Texas Instruments TI-92 Batteries Replacement: 2 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Batteries Replacement: 2 단계, 이미지 2개 중 2개
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Texas Instruments TI-92 Batteries Replacement: 3 단계, 이미지 2개 중 1개 Texas Instruments TI-92 Batteries Replacement: 3 단계, 이미지 2개 중 2개
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
  4. Texas Instruments TI-92 Batteries Replacement, Batteries: 4 단계, 이미지 3개 중 1개 Texas Instruments TI-92 Batteries Replacement, Batteries: 4 단계, 이미지 3개 중 2개 Texas Instruments TI-92 Batteries Replacement, Batteries: 4 단계, 이미지 3개 중 3개
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Daniel Maldonado
회원 가입일: 04/14/10
240 평판
안내서 9개를 작성함
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 회원
CPSU-GARNER-S10S15G51
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 7,614
