이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grab the back of the calculator with one hand and the cover with the other.
Pull the cover off from one of the sides for easy removal.
Orientate the calculator with the top facing towards you.
Slide the locking tab,found on the top part of the calculator, to the unlock position.
"Locking Tab"
To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
Then with the front of the calculator facing down, pull up on the back cover.
The calculator should now be orientated with the front facing down, as shown in picture 2.
Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
Now simply remove the battery.
Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
Unscrew the 19mm screw located near center of the back of the calculator.
Remove the panel being held by the screw.
Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
Lift one of the ends of the sticky black strips located around the screen.
This process will be facilitated by the use of the Ipod Opening Tools or a similar tool.
Start to remove the strips by pulling them outward carefully. Lift one end of the strip and peel it down to the other end.
If the strips are sticking to each other you do not need to separate them from each other, simply continue pulling outward on the strips around the edges.
If one of the remaining strips is sticking to the others and can not be easily removed, use a tool such as the Ipod Opening Tool to start pulling the strip up.
The yellow circles and the spots on the other side of the screen from the circles represent circular tabs holding the plastic screen cover in.
Use a flat tool such as the Ipod Opening tool to separate the screen from the tabs.
