주요 콘텐츠로 건너뛰기
Texas Instruments TI-Nspire CX OS Replacement
필요한 것
  1. Texas Instruments TI-Nspire CX OS Replacement, Try the built-in recovery tools.: 1 단계, 이미지 2개 중 1개 Texas Instruments TI-Nspire CX OS Replacement, Try the built-in recovery tools.: 1 단계, 이미지 2개 중 2개
    • Hold [doc], [enter], and [EE] at the same time.
    • Make sure battery is fully charged.
    • While still holding down the buttons, press the reset button located on the back of the calculator.
    • If the calculator doesn't power on automatically, keep holding down the buttons, then press the [on] key (twice in a row if necessary).
    • Select [0] first to reboot the calculator, if it does not help, press [2] to delete the OS.
    • Alternatively, remove the battery, hold down the buttons, then connect the calculator to a power source.
    • After the 'replace battery' warning appears, connect the battery and try the button combinations again.
    • Download and install the TI-Nspire Computer Link Software.
    • Go to TI's website and select your type of Nspire CX for the Technology box. Select 'connectivity software' for the View box.
    • Download the correct OS for your Nspire.
    • Go to TI's website and select your type of Nspire CX for the Technology box. Select 'Handheld Operating System' for the View box.
    • Connect your calculator to your computer via the USB A to mini USB B cable (the charging cable).
    • Launch the TI-Nspire Link Software on your computer. It should automatically detect your calculator.
    • Go to 'tools' in the top left hand corner and select 'install OS'. Select the OS you downloaded and the software will install it.
결론
If your calculator still will not turn on, contact TI Cares to see if they can get it back to working state: https://education.ti.com/en/contact-us
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
trogfield
회원 가입일: 11/01/14
459 평판
안내서 3개를 작성함
댓글 한 개
Hi! I have a TI-Nspire CX calculator, and now my calculator can’t turn on the screen. It’s broken maybe is because I am trying to upgrade the calculator to a TI-Nspire CX  CAS calculator. And, now I don’t know how to fix it. Can you please help me to fix it?
Wenqian Li - 답글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 39
지난 30일: 180
전체 시간: 16,770
