소개
Did the key fob to your 2006 Chevy Silverado stop working? Does the battery need to be replaced? Do you have a new key fob that needs to be programmed? Either way, it is possible to successfully replace the battery to your key fob and program it all on your own. This step-by-step guide will provide a detailed description on how to complete these tasks in very little time with no hassle.
필요한 것
Use the spudger to pry open the key fob shell by sliding it in between the front and back part of the key fob.
다른 한 분이 해당 안내서를 완성하였습니다.
