주요 콘텐츠로 건너뛰기
The Beatles Rock Band Drum Set Foot Pedal Replacement
필요한 것
  1. The Beatles Rock Band Drum Set Foot Pedal Replacement, Foot Pedal: 1 단계, 이미지 1/1
    • Unplug the coiled wire from back of upper assembly.
  2. The Beatles Rock Band Drum Set Foot Pedal Replacement: 2 단계, 이미지 1/1
    • Remove foot pedal from base assembly.
  3. The Beatles Rock Band Drum Set Foot Pedal Replacement: 3 단계, 이미지 1/1
    • Remove the two Phillips size J0 screws holding the cover plate on the top of the foot pedal.
  4. The Beatles Rock Band Drum Set Foot Pedal Replacement: 4 단계, 이미지 1/1
    • If this small sensor is broken, it is time to buy a new foot pedal and replace the broken one.
결론
Zach Richter
회원 가입일: 01/24/17
549 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-3, Banghart Winter 2017 Cal Poly, Team 13-3, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
How can I connect my rockband drums to my laptop to make it a personal drum pad?
clem4uandme - 답글
Email me
Abrajoe11@yahoo.com
Thanks
clem4uandme - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 40
전체 시간: 4,377
