주요 콘텐츠로 건너뛰기
The Beatles Rock Band Drum Set Front Button Replacement
필요한 것
  1. The Beatles Rock Band Drum Set Front Button Replacement, Front Buttons: 1 단계, 이미지 1/1
    • Remove the four Phillips size J1 screws from the corners of the bottom module.
    • Removing the screws requires a thin screwdriver.
  2. The Beatles Rock Band Drum Set Front Button Replacement: 2 단계, 이미지 1/3 The Beatles Rock Band Drum Set Front Button Replacement: 2 단계, 이미지 2/3 The Beatles Rock Band Drum Set Front Button Replacement: 2 단계, 이미지 3/3
    • Open the bottom module. Disconnect the five wire clips as shown in the pictures.
  3. The Beatles Rock Band Drum Set Front Button Replacement: 3 단계, 이미지 1/2 The Beatles Rock Band Drum Set Front Button Replacement: 3 단계, 이미지 2/2
    • Remove the four Phillips #1 sized screws holding the main circuit board. Rotate the board up and out, exposing the buttons.
  4. The Beatles Rock Band Drum Set Front Button Replacement: 4 단계, 이미지 1/1
    • The buttons can be pushed up from the bottom to be removed.
결론
Zach Richter
회원 가입일: 01/24/17
549 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-3, Banghart Winter 2017 Cal Poly, Team 13-3, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,215
