주요 콘텐츠로 건너뛰기
The Beatles Rock Band Hofner Bass Back Plate Replacement
필요한 것
  1. The Beatles Rock Band Hofner Bass Back Plate Replacement, Back Plate: 1 단계, 이미지 1/1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Back Plate Replacement: 2 단계, 이미지 1/1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Back Plate Replacement: 3 단계, 이미지 1/2 The Beatles Rock Band Hofner Bass Back Plate Replacement: 3 단계, 이미지 2/2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
결론
Jacob
회원 가입일: 01/25/17
601 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 824
