주요 콘텐츠로 건너뛰기
The Beatles Rock Band Hofner Bass Fret Buttons Replacement
필요한 것
  1. The Beatles Rock Band Hofner Bass Fret Buttons Replacement, Fret Buttons: 1 단계, 이미지 1/1
    • Flip the guitar onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 2 단계, 이미지 1/1
    • Flip the guitar to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 3 단계, 이미지 1/2 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 3 단계, 이미지 2/2
    • Flip the guitar on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the guitar is now open.
  4. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 4 단계, 이미지 1/1
    • Using a J1 Phillips screwdriver, unscrew the 10mm screw at the base of the neck.
  5. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 5 단계, 이미지 1/1
    • Remove the head of the guitar, at the top of the neck. Do this by simply pulling on it, it should slide off out fairly easily.
  6. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 6 단계, 이미지 1/1
    • Use a J1 Phillips screwdriver to remove three silver 10mm screws at the top of the neck.
  7. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 7 단계, 이미지 1/1
    • Pop off the red button at the top by prying.
    • Use a J1 Phillips screwdriver to remove the 10mm screw underneath.
  8. The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 8 단계, 이미지 1/2 The Beatles Rock Band Hofner Bass Fret Buttons Replacement: 8 단계, 이미지 2/2
    • Remove the 10mm screw on the fret buttons with a J1 Phillips screwdriver.
    • Remove the fret buttons.
결론
Jacob
회원 가입일: 01/25/17
601 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 28
전체 시간: 1,323
