소개
In this guide you will learn how to replace the whammy bar in a Rock Band Beatles Hofner Bass.
필요한 것
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
거의 끝나갑니다!
결론
