주요 콘텐츠로 건너뛰기
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
필요한 것
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: 1 단계, 이미지 1/1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 2 단계, 이미지 1/1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 3 단계, 이미지 1/2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 3 단계, 이미지 2/2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: 4 단계, 이미지 1/1
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 5 단계, 이미지 1/1
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 6 단계, 이미지 1/2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 6 단계, 이미지 2/2
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: 7 단계, 이미지 1/1
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
결론
Jacob
회원 가입일: 01/25/17
601 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 685
