주요 콘텐츠로 건너뛰기
The Claw "Claw" Replacement
필요한 것
  1. The Claw  "Claw" Replacement, Top Cover: 1 단계, 이미지 1/1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw  "Claw" Replacement: 2 단계, 이미지 1/1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw  "Claw" Replacement: 3 단계, 이미지 1/1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw  "Claw" Replacement: 4 단계, 이미지 1/1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw  "Claw" Replacement: 5 단계, 이미지 1/1
    • Remove the top cover of The Claw machine.
  6. The Claw  "Claw" Replacement: 6 단계, 이미지 1/2 The Claw  "Claw" Replacement: 6 단계, 이미지 2/2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw  "Claw" Replacement: 7 단계, 이미지 1/1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw  "Claw" Replacement, Claw: 8 단계, 이미지 1/1
    • Once you have removed the top cover of the claw you can easily access the claw and you will see that the claw is attached by two small chains.
    • Locate the small rings that attach the chain to the plastic claw.
  9. The Claw  "Claw" Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the precision tweezers or small needle nose pliers, gently widen the small rings enough so that they can be removed from the claw.
    • Replace the claw one ring at a time. The chain needs to be attached to the new claw in the same configuration. One side of the chain opens the claw and the other side is just a hanging support.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 18개 작성하였습니다
댓글 6개
Where do I buy a new grabber thing
Oliver Chew - 답글
The 1st joystick that moves the claw forward and back doesn’t work.
Michelle Bianchini - 답글
What if the chain won't go down as it deep as it used to be?
Mira DIP - 답글
Can you reconnect the white cord in picture above in step 6 connecting the claw on top and bottom
Greg Sturges - 답글
My chain fell off and I dont know how to fix
Kathellyn Da silva - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 100
전체 시간: 9,077
