주요 콘텐츠로 건너뛰기
The Claw Bottom Cover Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. The Claw Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Place The Claw in upright position with controls facing you.
  2. The Claw Bottom Cover Replacement: 2 단계, 이미지 1/1
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Bottom Cover Replacement: 3 단계, 이미지 1/1
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Bottom Cover Replacement: 4 단계, 이미지 1/2 The Claw Bottom Cover Replacement: 4 단계, 이미지 2/2
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Bottom Cover Replacement: 5 단계, 이미지 1/1
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: How To Solder and Desolder Connections.
결론
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 54
