주요 콘텐츠로 건너뛰기
The Claw Case Replacement
필요한 것
  1. The Claw Case Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Case Replacement: 2 단계, 이미지 1개 중 1개
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Case Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Case Replacement: 4 단계, 이미지 1개 중 1개
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Case Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the top cover of The Claw machine.
  6. The Claw Case Replacement: 6 단계, 이미지 2개 중 1개 The Claw Case Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Case Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Case Replacement, Case: 8 단계, 이미지 1개 중 1개
    • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
  9. The Claw Case Replacement: 9 단계, 이미지 1개 중 1개
    • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
  10. The Claw Case Replacement: 10 단계, 이미지 1개 중 1개
    • Gently remove the broken clear plastic case.
    • Remember how the case sat into the frame so that you can seat the new case in the same way.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개를 작성함
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 18개를 작성함
1가이드 댓글
where can i get the clear plastic panels
cristian2002 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 1,589
