주요 콘텐츠로 건너뛰기
The Claw Item Replacement
필요한 것
  1. The Claw Item Replacement, Top Cover: 1 단계, 이미지 1/1
    • Place The Claw machine in the up-right position with the control knobs facing you.
  2. The Claw Item Replacement: 2 단계, 이미지 1/1
    • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
  3. The Claw Item Replacement: 3 단계, 이미지 1/1
    • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
    • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
  4. The Claw Item Replacement: 4 단계, 이미지 1/1
    • Turn The Claw machine back to the upright position with controls facing you.
  5. The Claw Item Replacement: 5 단계, 이미지 1/1
    • Remove the top cover of The Claw machine.
  6. The Claw Item Replacement: 6 단계, 이미지 1/2 The Claw Item Replacement: 6 단계, 이미지 2/2
    • Remove the ten 6 mm phillips #1 screws from the top flange.
  7. The Claw Item Replacement: 7 단계, 이미지 1/1
    • Lift the flange upward and off to the side of the machine.
    • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
    • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
  8. The Claw Item Replacement, Overfill: 8 단계, 이미지 1/1
    • After emptying out contents have The Claw machine facing you
  9. The Claw Item Replacement: 9 단계, 이미지 1/1
    • View the Claw machine from the top
  10. The Claw Item Replacement: 10 단계, 이미지 1/1
    • Place thumb on grip section and pull away from the Claw machine.
  11. The Claw Item Replacement: 11 단계, 이미지 1/1
    • Place items in the Claw machine.
결론
Alain Pierre
회원 가입일: 03/22/16
1,188 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 회원
UMASSD-CATANIA-S16S4G8
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 23
전체 시간: 1,359
