주요 콘텐츠로 건너뛰기
The right way to remove HTC 10 screen
필요한 것
동영상 지침
결론
1. It is not possible to open HTC 10 lcd with spudger, knife, card;
2. We opened it under the help of suction cup;
3. The screen edges of HTC 10 cools down very quickly because of the metal back housing, so we should heat up the edges for several time and each time heat up for a quite long time.
다른 8명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,451 평판
안내서 378개 작성하였습니다
댓글 6개
Hi,
is there any tutorial for separating the digitizer from screen?
My screen is fine but the digitizer is broken.
Thanks for your help
Mahdi Mohammadi - 답글
What is your point showing us a card doesn't work..yet it is a useful tool in the end. Why don't you save us all some viewing time and show video showing just how to remove the screen?
Drew DeGraff - 답글
Took me 30 seconds to open with a heat plate and Exacto 17.
Max Dailey - 답글
What temp and time did you use? face up or down?
David Fear -
Thank you for this usefull video.
Easy Repair - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 15,869
