주요 콘텐츠로 건너뛰기
Thermaltake Theron Plus 5-pin USB Cord Replacement
필요한 것
  1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: 1 단계, 이미지 1/3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: 1 단계, 이미지 2/3 Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus 5-pin USB Cord Replacement: 2 단계, 이미지 1/2 Thermaltake Theron Plus 5-pin USB Cord Replacement: 2 단계, 이미지 2/2
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: 3 단계, 이미지 1/3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: 3 단계, 이미지 2/3 Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate the 5-pin connector on the mouse's motherboard.
    • Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
    • Once removed, place new 5-pin connector on in the same way.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Grace Neville
회원 가입일: 04/05/18
141 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 647
