주요 콘텐츠로 건너뛰기
ThinkPad T420 Hard Drive Replacement
필요한 것
  1. ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: 1 단계, 이미지 1/2 ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: 1 단계, 이미지 2/2
    • In most cases, it is better to reinstall the OS from scratch rather than image and restore. If the OS install is old, it is often overdue.
    • Before replacing the drive, backup your personal files. This can be done by hand, or automated.
  2. ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 2 단계, 이미지 1/3 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 2 단계, 이미지 2/3 ThinkPad T420 Hard Drive Replacement, Unplug the system/remove the battery: 2 단계, 이미지 3/3
    • If the system is plugged in, disconnect it from power and remove the battery. Slide the lock tab to the unlocked position.
    • While holding the tab in place, remove the battery.
  3. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 3 단계, 이미지 1/3 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 3 단계, 이미지 2/3 ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: 3 단계, 이미지 3/3
    • Remove the hard drive door from the system. Use a Phillips #1 bit.
    • Once the screw is loose, remove the drive cover as shown.
  4. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 4 단계, 이미지 1/3 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 4 단계, 이미지 2/3 ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: 4 단계, 이미지 3/3
    • Pull the black tab on the drive caddy to remove the drive.
  5. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 5 단계, 이미지 1/3 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 5 단계, 이미지 2/3 ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: 5 단계, 이미지 3/3
    • Remove the hard drive bumpers.
    • Remove the drive screws using a Phillips #1 screwdriver.
  6. ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: 6 단계, 이미지 1/2 ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: 6 단계, 이미지 2/2
    • Remove the old hard drive from the laptop. If you intend to keep it, store it in a antistatic bag if possible.
  7. ThinkPad T420 Hard Drive Replacement, Install the new hard drive: 7 단계, 이미지 1/2 ThinkPad T420 Hard Drive Replacement, Install the new hard drive: 7 단계, 이미지 2/2
    • If you are installing an SSD, a 7mm->9.5mm spacer may required.
    • Install your new drive using steps 6 through 3. Reinstall or reimage the operating system.
  8. ThinkPad T420 Hard Drive Replacement, Install the operating system: 8 단계, 이미지 1/1
    • If you are installing Windows, use an official ISO or purchase OEM installation media without a product key.
    • In order to save time setting up your system in the future, reinstall Windows from scratch and image the computer once all the drivers and updates are installed.
    • After reassembling the system and confirming the new drive is recognized, reinstall your operating system.
결론
Once you install the new hard drive, reassemble your computer in reverse order. Once you do this, install an OS and restore your data.
다른 6명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
89,943 평판
안내서 52개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 3개
Thank you for the meta notes
commander - 답글
Great instructions - you r doing a marvelous job - keep up the fine work !! God bless u !!!!
brixler jandley - 답글
Also - love the cat, I also am a cat fan big time !!!
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 39
전체 시간: 22,950
