주요 콘텐츠로 건너뛰기
ThinkPad X1 Carbon Battery Replacement
필요한 것
  1. ThinkPad X1 Carbon Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Unscrew the seven screws located on the back of the device
  2. ThinkPad X1 Carbon Battery Replacement: 2 단계, 이미지 1/1
    • Slide the plastic the spudger along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Battery Replacement: 3 단계, 이미지 1/1
    • Flip the device over and open it to lift the keyboard tray from the body of the device .
  4. ThinkPad X1 Carbon Battery Replacement: 4 단계, 이미지 1/1
    • Gently release the ribbon cable attached to the keyboard.
    • Gently Place keyboard tray to side.
  5. ThinkPad X1 Carbon Battery Replacement: 5 단계, 이미지 1/1
    • Unscrew the 4 screws holding the battery in place.
  6. ThinkPad X1 Carbon Battery Replacement: 6 단계, 이미지 1/1
    • Unlock and remove the ribbon cable running over the top of the battery.
  7. ThinkPad X1 Carbon Battery Replacement: 7 단계, 이미지 1/1
    • Gently pull the battery connection from the motherboard .
결론
Kirby Raines
회원 가입일: 01/23/18
657 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 318
