주요 콘텐츠로 건너뛰기
ThinkPad X1 Carbon Fan Replacement
필요한 것
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: 1 단계, 이미지 1개 중 1개
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: 2 단계, 이미지 1개 중 1개
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: 3 단계, 이미지 1개 중 1개
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: 5 단계, 이미지 1개 중 1개
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: 6 단계, 이미지 1개 중 1개
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mike
회원 가입일: 06/23/16
1,906 평판
안내서 5개를 작성함
iReconstruction iReconstruction 회원
Business
1 회원
안내서 16개를 작성함
댓글 한 개
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 28
지난 30일: 122
전체 시간: 13,795
