소개
You will learn how to open the ThinkPad X1 Carbon and replace the CPU Fan
필요한 것
Gently remove battery connector by pushing with the spudger in the direction of the arrow.
Remove four screws holding battery in place and remove battery.
Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
Loosen screws and pull fan up and out of the case.
Which generation X1 Carbon is this? I have a 1st Gen and a 5th Gen, neither match this layout. Please updated with the Generation in the title. Thank you.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
