주요 콘텐츠로 건너뛰기
ThinkPad X1 Carbon Fingerprint Reader Replacement
필요한 것
  1. ThinkPad X1 Carbon Fingerprint Reader Replacement, Fingerprint Reader: 1 단계, 이미지 1/1
    • Unscrew the seven screws located on the back of the device.
  2. ThinkPad X1 Carbon Fingerprint Reader Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opening tool along the edge of the device to separate the keyboard tray.
  3. ThinkPad X1 Carbon Fingerprint Reader Replacement: 3 단계, 이미지 1/1
    • Flip the device over and open it to lift the keyboard tray from the body of the device.
  4. ThinkPad X1 Carbon Fingerprint Reader Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to gently release the ribbon cable attached to the keyboard.
    • You may now place the device off to the side. The rest of the repair takes place on the keyboard tray.
  5. ThinkPad X1 Carbon Fingerprint Reader Replacement: 5 단계, 이미지 1/1
    • Locate the Fingerprint Reader and metal frame on the left side of the keyboard tray.
  6. ThinkPad X1 Carbon Fingerprint Reader Replacement: 6 단계, 이미지 1/1
    • Unscrew the two silver screws to remove the metal frame.
  7. ThinkPad X1 Carbon Fingerprint Reader Replacement: 7 단계, 이미지 1/1
    • Remove the ribbon cable connected to the board.
    • Remove and Replace the Fingerprint Reader board and metal frame.
    • This connection does not have a lock, please pull the ribbon away from the board. Do not attempt to lift the connection.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kirby Raines
회원 가입일: 01/23/18
657 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 33
전체 시간: 2,766
