주요 콘텐츠로 건너뛰기
ThinkPad X1 Carbon SSD Replacement
필요한 것
  1. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Use phillips #2 screwdriver to loosen seven cover screws.
  2. ThinkPad X1 Carbon SSD Replacement, Remove Bottom Cover: 2 단계, 이미지 1개 중 1개
    • Use spudger to pop open bottom cover, remove and set aside.
  3. ThinkPad X1 Carbon SSD Replacement, Disconnect Battery: 3 단계, 이미지 1개 중 1개
    • Disconnect the battery connector from the main board by pulling the connector towards the battery.
  4. ThinkPad X1 Carbon SSD Replacement, Remove SSD Screw: 4 단계, 이미지 1개 중 1개
    • Use the # 2 phillips screwdriver and remove the screw holding the SSD in place.
  5. ThinkPad X1 Carbon SSD Replacement, Remove SSD: 5 단계, 이미지 1개 중 1개
    • Remove the SSD by sliding it out of the connector to the right.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Mike
회원 가입일: 06/23/16
1,954 평판
안내서 5개를 작성함
iReconstruction iReconstruction 회원
Business
1 회원
안내서 17개를 작성함
8가이드 댓글
hi, can advise me which of the latest ssd 256/500 GB ssd's would work on a x1 carbon i5?
hardtail1969 - 답글
Really need to put the version/generation of the x1 carbon.. The gen 1 does not look like this inside and I’m spending way too much time trying to figure out what SSD it will take
Eric Metzger - 답글
Even for new models still can be used. same m.2 drive that might be located in the middle or top right of the device. Once the screws are off it is a very easy process.
jwalker8931 - 답글
I just replaced the SSD on my gen 6 and the steps are so easy: undo 5 screws, open up, undo 1 screw to loosen the M.2 module, replace and put things back together. There is no need to mess around with the battery connection at all.
haivu - 답글
A proper way, yes you need to disconnect the battery. You will learn it a hard way just a minor mistake, will blow your Mother Board and you will remember to disconnect them next time. The instruction is great.
Ryan Chau -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 103
지난 30일: 462
전체 시간: 52,522
