주요 콘텐츠로 건너뛰기
ThinkPad Yoga 12 Battery Replacement
필요한 것
  1. ThinkPad Yoga 12 Battery Replacement, Screws: 1 단계, 이미지 1/3 ThinkPad Yoga 12 Battery Replacement, Screws: 1 단계, 이미지 2/3 ThinkPad Yoga 12 Battery Replacement, Screws: 1 단계, 이미지 3/3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
    Ten screws, but who’s counting. Thank you!
    jthrall - 답글
  2. ThinkPad Yoga 12 Battery Replacement, Prying: 2 단계, 이미지 1/2 ThinkPad Yoga 12 Battery Replacement, Prying: 2 단계, 이미지 2/2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: 3 단계, 이미지 1/1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: 4 단계, 이미지 1/2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: 4 단계, 이미지 2/2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: 5 단계, 이미지 1/2 ThinkPad Yoga 12 Battery Replacement, Lift: 5 단계, 이미지 2/2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: 6 단계, 이미지 1/3 ThinkPad Yoga 12 Battery Replacement, Connecter: 6 단계, 이미지 2/3 ThinkPad Yoga 12 Battery Replacement, Connecter: 6 단계, 이미지 3/3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
결론
다른 9명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 03/18/18
1,324 평판
안내서 3개 작성하였습니다
댓글 한 개
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 38
전체 시간: 6,548
