주요 콘텐츠로 건너뛰기
ThinkPad Yoga 12 Bottom Cover Removal
필요한 것
  1. ThinkPad Yoga 12 Bottom Cover Removal, Screws: 1 단계, 이미지 1/3 ThinkPad Yoga 12 Bottom Cover Removal, Screws: 1 단계, 이미지 2/3 ThinkPad Yoga 12 Bottom Cover Removal, Screws: 1 단계, 이미지 3/3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Bottom Cover Removal, Prying: 2 단계, 이미지 1/2 ThinkPad Yoga 12 Bottom Cover Removal, Prying: 2 단계, 이미지 2/2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Bottom Cover Removal, Lift off cover: 3 단계, 이미지 1/1
    • Lift off the cover, and you're done!
결론
To reassemble, place the bottom cover on and push until you hear a satisfying click. Keep doing this until the whole cover is secured. Then, screw all of the screws back in!
다른 3명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 03/18/18
1,324 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,451
