주요 콘텐츠로 건너뛰기
Three-way Switch Replacement
필요한 것
  1. Three-way Switch Replacement, Three-way Switch: 1 단계, 이미지 2개 중 1개 Three-way Switch Replacement, Three-way Switch: 1 단계, 이미지 2개 중 2개
    • Locate and turn off the circuit breaker for your switch.
    • Try to turn the switch to ensure you turned the power off.
  2. Three-way Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Use the screwdriver to remove the 15mm Flathead screws on the wall plate.
    • Remove the wall plate from the wall.
  3. Three-way Switch Replacement, Determine voltage absence: 3 단계, 이미지 2개 중 1개 Three-way Switch Replacement, Determine voltage absence: 3 단계, 이미지 2개 중 2개
    • While wearing insulated gloves, gently pull out the switch and use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
    • You can also use a single pole phase tester, but that's not the proper way to do it.
    • Do not work on live circuits if you are not an experienced professional.
  4. Three-way Switch Replacement: 4 단계, 이미지 3개 중 1개 Three-way Switch Replacement: 4 단계, 이미지 3개 중 2개 Three-way Switch Replacement: 4 단계, 이미지 3개 중 3개
    • Label the black live or load wire which connects to the power or the device and usually on the down position of the switch.
    • Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
  5. Three-way Switch Replacement: 5 단계, 이미지 2개 중 1개 Three-way Switch Replacement: 5 단계, 이미지 2개 중 2개
    • Label the two traveler wires where the up position is held by gold screws of the old switch.
  6. Three-way Switch Replacement: 6 단계, 이미지 3개 중 1개 Three-way Switch Replacement: 6 단계, 이미지 3개 중 2개 Three-way Switch Replacement: 6 단계, 이미지 3개 중 3개
    • Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires.
    • After the wires are removed, disconnect the old switch.
  7. Three-way Switch Replacement: 7 단계, 이미지 2개 중 1개 Three-way Switch Replacement: 7 단계, 이미지 2개 중 2개
    • You will find there are one or two wires left in the outlet box.
    • Ground wire is the bare copper wire.
    • The white one is the neutral wire that may be in another outlet box.
    • Please label the neutral wire and the ground wire.
  8. Three-way Switch Replacement: 8 단계, 이미지 3개 중 1개 Three-way Switch Replacement: 8 단계, 이미지 3개 중 2개 Three-way Switch Replacement: 8 단계, 이미지 3개 중 3개
    • Using your new switch, link two traveler wires to the positions with gold screws of the new switch and tighten the 5mm Phillips #1 screws.
    • Link the live or load wire to the position with a black screw and tighten the 5mm Phillips #1 screw.
    • Please ensure you link the wires to the correct places.
  9. Three-way Switch Replacement: 9 단계, 이미지 2개 중 1개 Three-way Switch Replacement: 9 단계, 이미지 2개 중 2개
    • If there is a green 5mm Phillips #1 screw on the new switch, please link the ground wire to and tighten it.
    • For the intelligent switch, there would be a green wire so that you can group the ground wire with the green wire and tighten them with a wire nut.
  10. Three-way Switch Replacement: 10 단계, 이미지 2개 중 1개 Three-way Switch Replacement: 10 단계, 이미지 2개 중 2개
    • There is an extra white wire on the intelligent switch.
    • Group the neutral wire with the white wire and use the wire nut to tighten them.
  11. Three-way Switch Replacement: 11 단계, 이미지 3개 중 1개 Three-way Switch Replacement: 11 단계, 이미지 3개 중 2개 Three-way Switch Replacement: 11 단계, 이미지 3개 중 3개
    • Turn the power on and check whether the new switch works.
    • Gently push the wires back into the outlet box.
    • You’ll also need to leave some space for the switch.
    • Secure the new switch with the 10mm Phillips #1 screws.
    • Finally, secure the wall plate.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Tao Zhuo
회원 가입일: 01/19/21
256 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 46
전체 시간: 2,252
