주요 콘텐츠로 건너뛰기
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
필요한 것
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: 1 단계, 이미지 1/1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 2 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 2 단계, 이미지 2/2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 3 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 3 단계, 이미지 2/2
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 4 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 4 단계, 이미지 2/2
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 5 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 5 단계, 이미지 2/2
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 6 단계, 이미지 1/1
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 7 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 7 단계, 이미지 2/2
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 8 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 8 단계, 이미지 2/2
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 9 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 9 단계, 이미지 2/2
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 10 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 10 단계, 이미지 2/2
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 11 단계, 이미지 1/1
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 12 단계, 이미지 1/1
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
결론
Aaron Banaga
회원 가입일: 09/11/17
526 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G1
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 15
전체 시간: 1,574
