주요 콘텐츠로 건너뛰기
Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement
필요한 것
  1. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, J1 Screws on Throttle: 1 단계, 이미지 1/1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: 2 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Panel: 2 단계, 이미지 2/2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: 3 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement, Throttle Rudder: 3 단계, 이미지 2/2
    • Remove the four 13 mm J1 JIS head screws from the rudder assembly holder.
  4. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: 4 단계, 이미지 1/1
    • Gently remove the panel that is covering the rudder.
  5. Thrustmaster T Flight Hotas 4 Throttle Rudder Replacement: 5 단계, 이미지 1/1
    • Proceed to remove the rudder from the throttle.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Julissa Orozco
회원 가입일: 09/20/17
351 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G1
3 회원들
안내서 13개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 1,849
