주요 콘텐츠로 건너뛰기
Thrustmaster T Flight Hotas 4 Trigger Replacement
필요한 것
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: 1 단계, 이미지 1/2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: 1 단계, 이미지 2/2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 2 단계, 이미지 1/3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 2 단계, 이미지 2/3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 2 단계, 이미지 3/3
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: 3 단계, 이미지 1/1
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: 4 단계, 이미지 1/3 Thrustmaster T Flight Hotas 4 Trigger Replacement: 4 단계, 이미지 2/3 Thrustmaster T Flight Hotas 4 Trigger Replacement: 4 단계, 이미지 3/3
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
결론
Aaron Banaga
회원 가입일: 09/11/17
526 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G1
3 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 19
전체 시간: 3,391
