소개
The goal of this guide is to show how to replace the trigger so it will function smoothly.
필요한 것
Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
Carefully remove the paneling of the joystick using your hands to pull the panels apart.
This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
거의 끝나갑니다!
결론
