주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Thrustmaster T3PM Maintenance
필요한 것
  1. Thrustmaster T3PM Maintenance, Disconnect the pedal heads: 1 단계, 이미지 2개 중 1개 Thrustmaster T3PM Maintenance, Disconnect the pedal heads: 1 단계, 이미지 2개 중 2개
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
    • Before starting, unplug your T3PM.
  2. Thrustmaster T3PM Maintenance, Remove screws from the bottom: 2 단계, 이미지 1개 중 1개
    • Using Phillips screwdriver remove all screws at the bottom.
  3. Thrustmaster T3PM Maintenance, Remove the top cover: 3 단계, 이미지 1개 중 1개
    • Remove the top cover and put it aside
    • Clean off any dust, residue, pet hair and other foreign debris that has accumulated inside the pedal set.
  4. Thrustmaster T3PM Maintenance, Inspect the wires and tape.: 5 단계, 이미지 2개 중 1개 Thrustmaster T3PM Maintenance, Inspect the wires and tape.: 5 단계, 이미지 2개 중 2개
    • Make sure that the wires and the main cable are secure.
    • Replace sticky tape if necessary.
  5. Thrustmaster T3PM Maintenance, Thoroughly clean each pedal.: 6 단계, 이미지 1개 중 1개
    • Clean off any dust, residue, pet hair etc from the pedals themselves, near the sensors and springs.
    • Make sure to clean off the extremities of the pedals.
  6. Thrustmaster T3PM Maintenance, Clean the sensors: 7 단계, 이미지 2개 중 1개 Thrustmaster T3PM Maintenance, Clean the sensors: 7 단계, 이미지 2개 중 2개
    • Using an air-blower, compressed air-can or other tool, clean the sensors.
    • Be cautions as to not damage the sensors, wires or the connectors.
    • Watch out for Electro-static Discharge. Make sure not to touch the sensors or use anti-static wrist strap.
  7. Thrustmaster T3PM Maintenance, Inspect the springs.: 8 단계, 이미지 1개 중 1개
    • Inspect the conditions of the gas and clutch springs.
    • Re-lubricate if necessary.
결론
To reassemble your device, follow the steps 1,2,3 in reverse order.
작성자
1다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,600 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 86
전체 시간: 1,508
