소개
Use this guide to replace broken gas or break pedal.
필요한 것
Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 6개
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
I am also looking for this spring. Any help would be appreciated.
thanks
Me too. Are these springs available?
I only need 1 spring, not 10....
Anyone selling 1 spring?
