주요 콘텐츠로 건너뛰기
Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement
필요한 것
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 2 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 2 단계, 이미지 2/2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 3 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 3 단계, 이미지 2/2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mario Nunez
회원 가입일: 10/18/17
421 평판
안내서 3개 작성하였습니다
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G33
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - 답글
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 42
전체 시간: 5,494
