소개
This guide will show you how to replace the connection port for the pedals.
필요한 것
Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
By pulling up on both ends of the port you will be able to pull out the port to remove it.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
