주요 콘텐츠로 건너뛰기
Thustmaster Ferrari 458 Spider Racing Wheel motherboard Replacement
필요한 것
  1. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Bottom Cover: 1 단계, 이미지 1/1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: 2 단계, 이미지 1/2 Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement: 2 단계, 이미지 2/2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel motherboard  Replacement, Motherboard: 3 단계, 이미지 1/1
    • Using a small plastic opening tool, gently pry up the white connector that connects the USB cable to the board.
    • Cut the black cable as close to the board as possible.
    • Remove the three screws using PH2 screw driver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mohammed Alsogair
회원 가입일: 10/18/17
339 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 회원
USFT-CAGLE-F17S1G33
4 회원들
안내서 5개 작성하였습니다
댓글 3개
how can I replace elastic cord?
geoff - 답글
Just so every one knows its easier then changing a baby's arse for the first ten times if any one hasn’t yet I'm not gunna paint a picture I'm just going to sit here and smile. But as I was saying I found what was wrong just got to get my parts and fit as easy as that and if you don't know or butter for fingers then just let some other capable suspect do it, Save money.
scott_vernon85 - 답글
Where did you get a replacement motherboard?
Paul Stewart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 46
전체 시간: 5,353
