주요 콘텐츠로 건너뛰기
TiVo Premiere XL4 Cover Replacement
필요한 것
  1. TiVo Premiere XL4 Cover Replacement, Case: 1 단계, 이미지 1/1
    • Power down the TiVo Premiere XL4 by detaching the power cable from the unit and power source.
    • Allow the box to cool for at least 5 minutes before proceeding to the next step.
  2. TiVo Premiere XL4 Cover Replacement: 2 단계, 이미지 1/2 TiVo Premiere XL4 Cover Replacement: 2 단계, 이미지 2/2
    • Remove the four 80 mm T10 screws from the back of the TiVo box using theTorx screwdriver.
  3. TiVo Premiere XL4 Cover Replacement: 3 단계, 이미지 1/1
    • Take the outer casing by sliding the top of the box off of the component carefully, making sure not to damage the surrounding components inside.
결론
Frances Prewitt
회원 가입일: 10/22/18
661 평판
안내서 6개 작성하였습니다
Baylor, Team S1-G1, Williams Fall 2018 Baylor, Team S1-G1, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 85
