소개
The battery acts as an internal power source for the device. In case this battery needs to be replaced, this simple guide will walk you through the steps of removing the current battery to replace it.
부품
부품은 필요하지 않습니다.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
    • Lift the cover up and off the device.
    • Locate the battery on the motherboard.
    • Using the spudger, wedge the metal clip off of the top surface of the battery.
    • Use your finger to push the battery sideways out of its holder.
결론
Cody Hunter
회원 가입일: 2011년 10월 10일
22 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G33
4 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 9
전체 시간: 1,360
