주요 콘텐츠로 건너뛰기
TiVo Series 2 TCD24008A Hard Drive Replacement
필요한 것
  1. TiVo Series 2 TCD24008A Hard Drive Replacement, Cover: 1 단계, 이미지 1/1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Hard Drive Replacement: 3 단계, 이미지 1/1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Locate the hard drive.
  5. TiVo Series 2 TCD24008A Hard Drive Replacement: 5 단계, 이미지 1/2 TiVo Series 2 TCD24008A Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the ribbon cable by applying firm pressure to the black tabs on the sides.
    • Remove the power cable to the right of the ribbon cable.
  6. TiVo Series 2 TCD24008A Hard Drive Replacement: 6 단계, 이미지 1/3 TiVo Series 2 TCD24008A Hard Drive Replacement: 6 단계, 이미지 2/3 TiVo Series 2 TCD24008A Hard Drive Replacement: 6 단계, 이미지 3/3
    • Unscrew the 0.31 inch T-9 screws from the hard drive and pull outwards to remove.
결론
Talha
회원 가입일: 10/11/11
31 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G33
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 15
전체 시간: 1,744
