주요 콘텐츠로 건너뛰기
TiVo Series 2 TCD24008A Motherboard Replacement
필요한 것
  1. TiVo Series 2 TCD24008A Motherboard Replacement, Cover: 1 단계, 이미지 1/1
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Motherboard Replacement: 2 단계, 이미지 1/1
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Motherboard Replacement: 3 단계, 이미지 1/1
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. TiVo Series 2 TCD24008A Motherboard Replacement: 5 단계, 이미지 1/1
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  6. TiVo Series 2 TCD24008A Motherboard Replacement: 6 단계, 이미지 1/1
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  7. TiVo Series 2 TCD24008A Motherboard Replacement: 7 단계, 이미지 1/1
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  8. TiVo Series 2 TCD24008A Motherboard Replacement: 8 단계, 이미지 1/1
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  9. TiVo Series 2 TCD24008A Motherboard Replacement: 9 단계, 이미지 1/2 TiVo Series 2 TCD24008A Motherboard Replacement: 9 단계, 이미지 2/2
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  10. TiVo Series 2 TCD24008A Motherboard Replacement: 10 단계, 이미지 1/1
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  11. TiVo Series 2 TCD24008A Motherboard Replacement: 11 단계, 이미지 1/2 TiVo Series 2 TCD24008A Motherboard Replacement: 11 단계, 이미지 2/2
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
결론
Cody Hunter
회원 가입일: 10/10/11
22 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G33
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,078
