주요 콘텐츠로 건너뛰기
TiVo Series 2 TCD540080 Cooling Fan Replacement
필요한 것
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: 1 단계, 이미지 1/1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: 3 단계, 이미지 1/2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 3 단계, 이미지 2/2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 1/1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: 5 단계, 이미지 1/2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: 6 단계, 이미지 1/2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 6 단계, 이미지 2/2
    • Pull the fan towards the front and out of the TiVo unit.
결론
Svyatoslav Markeyev
회원 가입일: 04/16/10
135 평판
안내서 5개 작성하였습니다
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G79
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 5,261
