주요 콘텐츠로 건너뛰기
TiVo Series 2 TCD540080 Motherboard Replacement
필요한 것
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: 1 단계, 이미지 1/1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: 3 단계, 이미지 1/2 TiVo Series 2 TCD540080 Motherboard Replacement: 3 단계, 이미지 2/2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: 7 단계, 이미지 1/1
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: 8 단계, 이미지 1/1
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: 9 단계, 이미지 1/1
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: 10 단계, 이미지 1/3 TiVo Series 2 TCD540080 Motherboard Replacement: 10 단계, 이미지 2/3 TiVo Series 2 TCD540080 Motherboard Replacement: 10 단계, 이미지 3/3
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: 11 단계, 이미지 1/1
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Svyatoslav Markeyev
회원 가입일: 04/16/10
135 평판
안내서 5개 작성하였습니다
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 회원
CPSU-JOHANN-S10S33G79
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 4,455
