주요 콘텐츠로 건너뛰기
Tightening Mt. Fury Roadmaster Brake Cables
필요한 것
  1. Tightening Mt. Fury Roadmaster Brake Cables, Tightening Mt. Fury Roadmaster Brake Cables: 1 단계, 이미지 1/1
    • Loosen the bolt that clamps the brake cable on the brake caliper with the 10mm open-end wrench.
  2. Tightening Mt. Fury Roadmaster Brake Cables: 2 단계, 이미지 1/1
    • Pull the brake cable until proper tension is acquired and the cable shows resistance.
  3. Tightening Mt. Fury Roadmaster Brake Cables: 3 단계, 이미지 1/1
    • Re-tighten the clamping nut.
  4. Tightening Mt. Fury Roadmaster Brake Cables: 4 단계, 이미지 1/1
    • If necessary, adjust the positioning of the caliper arms by loosening the dome nut at the pivot point and manually shifting the arms in the desired direction.
  5. Tightening Mt. Fury Roadmaster Brake Cables: 5 단계, 이미지 1/1
    • For more precise adjustment of the brake cable tension, use pliers to tighten the barrel nut at the opposite ends of the handlebars on the brake levers.
결론
Your brakes should be fully tightened now.
다른 11명이 해당 안내서를 완성하였습니다.
Samantha Rawlins
회원 가입일: 01/21/14
476 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-40, Maness Winter 2014 Cal Poly, Team 1-40, Maness Winter 2014 회원
CPSU-MANESS-W14S1G40
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Thank God I didn’t have to watch someone's long winded 10 minute video explaining this.  lol Thank you for that!  Great article.  Thanks for helping me out!
rtinmotion - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 15
전체 시간: 3,303
